Internal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_wys_titan.cpp, Line: 1212
We have some found problem during project compilation using Quartus Prime Lite 18.1 in a specific computer model that we are using. Exactly same error with the same project in two computers of that same laptop model (MSI GS63) but project compiles ok in other different computers, we have already tried with a workstation and a Dell laptop, all the computers with Windows 10 Pro 64-bit OS. So it seems something machine-related but not because of a hardware component failure, and it's a problem because we planned to substitute laptops of all development team members.
-Tried deleting db and temp folders.
-Tried cleaning out project.
No sucess in any case.
As the error causing that Quartus exception is always in the same line of code and in the same file, I hope somebody can take a look at that line of code and drop us some hints or ideas to understand what is happening. Any help would be very much appreciated.
Problem Details
Error:
Failed to initialize pll info.
Stack Trace:
0x10ee7d: CDB_SGATE_WYS_PROCESS_PARAM_IMPL::process_parameter_titan_pll_charge_pump_current_common + 0x4f1 (db_cdb_sgate)
0xf4008: CDB_SGATE_WYS_PROCESS_PARAM_IMPL::visit_cuda_pll + 0x14a4 (db_cdb_sgate)
0x421a: CDB_SGATE_WYS_PROCESS_PARAM::process_parameters + 0x26 (db_cdb_sgate)
0x43ca: cdb_sgate_check_and_process_wysiwyg_parameters + 0x62 (db_cdb_sgate)
0xe0ed1: SGN_FN_LIB::sgate_wysiwyg_mapper + 0x1c01 (synth_sgn)
0xe37eb: SGN_FN_LIB::start_vrf_flow + 0x3b (synth_sgn)
0xe1d9b: SGN_FN_LIB::start + 0xa1b (synth_sgn)
0xc294a: SGN_EXTRACTOR::single_module_extraction + 0x15a (synth_sgn)
0xb7524: SGN_EXTRACTOR::recursive_extraction + 0x204 (synth_sgn)
0xb6e6f: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist + 0x36f (synth_sgn)
0xb757b: SGN_EXTRACTOR::recursive_extraction + 0x25b (synth_sgn)
0xb08c3: SGN_EXTRACTOR::extract + 0x1d3 (synth_sgn)
0x1324e: sgn_qic_full + 0x19e (synth_sgn)
0x4351: qsyn_execute_sgn + 0x131 (quartus_map)
0x13f9c: QSYN_FRAMEWORK::execute_core + 0x12c (quartus_map)
0x13aa6: QSYN_FRAMEWORK::execute + 0x496 (quartus_map)
0x112bc: qexe_do_normal + 0x1ec (comp_qexe)
0x16142: qexe_run + 0x432 (comp_qexe)
0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
0x1b08b: qsyn_main + 0x51b (quartus_map)
0x12e98: msg_main_thread + 0x18 (CCL_MSG)
0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
0x12761: msg_exe_main + 0xa1 (CCL_MSG)
0x29872: __tmainCRTStartup + 0x10e (quartus_map)
0x17bd3: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6ced0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_map
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 18.1.0
Build: 625
Edition: Lite Edition
- KennyT_altera
I try on linux and there are no failure. We have seen this in the past, after user install all the device for the Quartus, it passed. Can you check on your side?
- jimmay
I recently encountered problems matching the Quartus exception from the OP. Tried compilation on Linux with no success. Installed the complete software with all devices as you suggested and compilation was successful. Good to go now. Thanks for your help!
- KennyT_altera
Hi Marc,
Can you attached your design.qar file here? Let me know if you want to attached your design privately.
- mblanch
Hello KTan,
I would like to share that design file privately, I already have it prepared. Please can you enable private messaging capability for the files sharing?
BTW, later we can share solution here for other users having similar problem.
BR
- KennyT_altera
Hi Marc,
You can check your inbox on this.
Kenny
- mblanch
Hi Kenny,
I have added the files on the inbox, some days ago, have you already received them? Is there any news on the topic, as it is blocking us. Thanks!
BR,
Marc
- KennyT_altera
Hi Marc,
I will look into this asap.
Kenny
- KennyT_altera
Hi Marc,
Seems like we cannot duplicate the case. Since this issue was related to PLL. Can you help to do two things in windows?
1) Delete and regenerate the PLL for the project.
2) Check what software is running in the background, in the past we had customer having NI software causing the crash.
- KennyT_altera
Any update?
- KennyT_altera
Any update?
