mblanch
6 years agoInternal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_wys_titan.cpp, Line: 1212
Hello, We have some found problem during project compilation using Quartus Prime Lite 18.1 in a specific computer model that we are using. Exactly same error with the same project in two computers o...
KennyT_altera
6 years agoI try on linux and there are no failure. We have seen this in the past, after user install all the device for the Quartus, it passed. Can you check on your side?
- jimmay6 years ago
I recently encountered problems matching the Quartus exception from the OP. Tried compilation on Linux with no success. Installed the complete software with all devices as you suggested and compilation was successful. Good to go now. Thanks for your help!
