13 years agoInternal Error during Fitter (Place & Route) when compiling a PCIe x1 demo
Hello all,
First time poster, thanks in advance for reading. I'm experiencing an Internal error during the Fitter (Place and Route) stage and it's 100% reproducible with no obvious workaround. Stack trace below. Environment is Quartus II 12.1sp1 on Windows 7 32bit. Using the Cyclone IV GX PCIe development kit DK-DEV-4CGX150N I've downloaded the associated GX iv software kit (cycloneIVGX_4cgx150_fpga_v12.1.0.exe). I'm attempting to compile the vanilla reference project 'c4gx_PCIe_gen1_x1' with zero changes. I've unpacking the c4gx_PCIe_gen1_x1.QAR multiple times and compiled with/without removing the incremental_db and db dirs, it always fails at the same Fitter stage. Another member posted the same stack trace (roughly 3 weeks ago) but it the post trailed off with no obvious conclusion than 'send the archive to a specific email address'. It wasn't clear whether he was using this project codebase or something completely different. Any help or advise would be welcome. Thanks, - Steve Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_wire_maps.c, Line: 1546 Internal Error Stack Trace: 0x1f6eec: _vpr_qi_jump_to_exit + 0x64 (fitter_vpr20kmain) 0x2b9162: _aa_pl_global_create_initial_placement_hints + 0xad (fitter_vpr20kmain) 0x2b919b: _vpr_exit_at_line + 0x37 (fitter_vpr20kmain) 0x2323da: _handle_assertion_failure_stripped + 0x25 (fitter_vpr20kmain) 0x1d172c: ___sse2_available_init + 0x82728 (fitter_vpr20kmain) 0x20177: _Dinkum_std::vector<_Dinkum_std::set<int,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<int> >,MEM_STL_ALLOCATOR<_Dinkum_std::set<int,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<int> > > >::_Insert_n + 0x2a7 (fitter_vpr20kmain) 0xf3838: _aa_rt_wire_maps_update_with_current_routing + 0x88 (fitter_vpr20kmain) 0x17c3d: _aa_rt_update_wire_maps_update_after + 0x7d (fitter_vpr20kmain) 0x2d2ff: _aa_rt_timing_tamer_has_router_converged + 0x32f (fitter_vpr20kmain) 0x2b66c: _vpr_qi_thr_mutex_destroy + 0xfc (fitter_vpr20kmain) 0x146d3: _aa_fsda_router_compute_pin_connection_delay_chain_groups + 0x83 (fitter_vpr20kmain) 0x128ed4: _aa_route_alg_perform_timing_driven_route + 0x24 (fitter_vpr20kmain) 0x11584a: _aa_route_try_route + 0x6a (fitter_vpr20kmain) 0x110c5e: _Dinkum_std::vector<_Dinkum_std::_Hash<_Dinkum_std::_Hmap_traits<int,int,_Dinkum_std::hash_compare<int,_Dinkum_std::less<int> >,MEM_STL_ALLOCATOR<_Dinkum_std::pair<int,int> >,0> >::iterator,MEM_STL_ALLOCATOR<_Dinkum_std::_Hash<_Dinkum_std::_Hmap_traits<int,int,_Dinkum_std::hash_compare<int,_Dinkum_std::less<int> >,MEM_STL_ALLOCATOR<_Dinkum_std::pair<int,int> >,0> >::iterator> >::resize + 0x18e (fitter_vpr20kmain) 0x12e22b: _cl_free_do_clustering_short_life_data + 0x15b (fitter_vpr20kmain) 0x11cd36: _aa_flow_fit + 0x66 (fitter_vpr20kmain) 0x10dc8d: _vpr_main_internal + 0x2ad (fitter_vpr20kmain) 0x13b35a: VPR_QI_FACADE::vpr_qi_main + 0xfa (fitter_vpr20kmain) 0x2cfaf: _fitapi_run_vpr + 0x6f (fitter_fitapi) 0x38374: FITCC_EXPERT::run_vpr + 0xf4 (FITTER_FITCC) 0x39f5f: FITCC_EXPERT::place_and_route + 0x13f (FITTER_FITCC) 0x3bb1d: FITCC_EXPERT::invoke_fitter + 0x64d (FITTER_FITCC) 0x4f88: _fcuda_execute + 0x1c8 (fitter_fcuda) 0xa26b: fmain_start + 0x69b (FITTER_FMAIN) 0x7835: qfit_execute_fit + 0x195 (quartus_fit) 0x1179b: QFIT_FRAMEWORK::execute + 0x4ab (quartus_fit) 0xfbb1: qexe_get_tcl_sub_option + 0x1641 (comp_qexe) 0x1203b: qexe_process_cmdline_arguments + 0x3cb (comp_qexe) 0x12123: qexe_standard_main + 0x83 (comp_qexe) 0xb5be: qfit_main + 0x5e (quartus_fit) 0x4d41: msg_main_thread + 0x11 (CCL_MSG) 0x1be8: _thr_final_wrapper + 0x8 (ccl_thr) 0x5425: msg_thread_wrapper + 0x85 (CCL_MSG) 0x37f7: mem_thread_wrapper + 0x47 (ccl_mem) 0x6051: msg_exe_main + 0x81 (CCL_MSG) 0xb84c: _main + 0x1c (quartus_fit) 0x13053: _memset + 0x15f (quartus_fit) 0x4ed6b: BaseThreadInitThunk + 0x11 (kernel32) 0x637f4: RtlInitializeExceptionChain + 0xee (ntdll) 0x637c7: RtlInitializeExceptionChain + 0xc1 (ntdll) End-trace Quartus II 32-bit Version 12.1 Build 243 01/31/2013 SJ Web Edition Service Pack Installed: 1
