13 years ago --- Quote Start --- Its probably to do with the memory requirements. I think that the min required memory (or at least min recommended) is 4GB. The most the 32bit exe can get is 3gb --- Quote End --- Quartus shouldn't crash though. I recently ran Quartus 11.1sp1 32-bit (WinXP) on a Stratix IV GX 530K design. Eventually the design failed with an out-of-memory error message. I then ran the same design on Quartus 12.1 32-bit (Win7) and it immediately gave an error message indicating to use the 64-bit version, which I did, and it synthesized fine. So there are clearly some error checks in place ... though I guess they are not thorough enough. Cheers, Dave
