Interfacing switches with led in de-1 soc using nios v processor in quartus prime software
I hope that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- lis31 year ago
I believe this problem is not solved. At least, the links you provided in your last post are not enough to help him to solve the problem.
there are some difference between Nios V and Nios II. In the Platform Designer, the connections will be different. He may be able to figure out how to make the qsys work. He may also be able to figure out how to make the LEDs ( or/and switches) work, but he will have great trouble to print "hello world".
Intel needs to provide tutorial materials for new versions of Quartus Prime. Since version 18.1, Intel did not do a good job as before (Altera).
At this moment, Version 24.1, the Platform Designer + Ashling RiscFree IDE is worse. 1. Installation won't give a entry for Ashling in the Start menu. 2. Someone may think by manually starting the Ashling it by using mouse clicking will be OK. No, it is not the case, the Ashling has to be started within the Nios V shell. 3. Again, needs to see the printf() result in the Jtag UART console. 3. Ashling RiscFree IDE cannot stop application running on the Nios system. This gives a lots of trouble during the application testing cycle, because has to power off-on the DE1 board, re-download the quartus project, and then run the nios v applicaition again.
