kiiii's avatar
kiiii
6 years ago
Intel HLS 18.1 synthesis takes forever
Hi, I am new to Intel HLS and I have version 18.1 lite installed. I tried to run the example programs named loop_memory_dependency and the runtime for calling the build.bat and getting the executable is around 50 minutes. Did I do something wrong? Or is this normal for running under the Windows environment?
1 Reply
  • AnilErinch_A_Intel's avatar
    AnilErinch_A_Intel
    Hi ,
    It is perfectly normal to have compilation time of loop_memory_dependency example to approach 1 hr.
    since it involves conversion C++ code to production quality RTL code,there are many additional operations happening while compared to normal C++ compilation aimed to produce an executable in Windows machine.
    Hope that Helps.
    Thanks and Regards
    Anil
