User1582192733150209
6 years agoIntel fft simulation with Modelsim 10.5c starter version /Quartus prime pro 17.1/Aria10gx
Hello Sir/Madam, Quartus prime pro 17.1 + Modelsim 10.5c +Arria10gx I generated an Intel FFT ipcore from Quartus, I can see some files have been generated under the tfft_17_1_0_240_restored\ft\sim\...
6 years agoHi ShYanYewT,
Thanks for your support.
I have check the testbench generated by IP tools, I am pretty believe that testbench has installed all the modules
1, clk_bfm ,use to generate clk output
2, _rst_bfm, use to generate reset output
3, sink_bfm, with clk and reset 2 signal inputs and generate all the sink signals feed to fft IP core
4, source_bfm, with clk and reset 2 signal inputs and generate all the source signals for receiving the fft IP result from FFT IP.
I am not sure what kind of stimulus logic does customer need to add into this fully assembled testbench?
from the error information ,I guess it is just a sink and source BFM wrongly behaved.
but clk and rst BFM are working well.
Jim
