User1582192733150209
6 years agoIntel fft simulation with Modelsim 10.5c starter version /Quartus prime pro 17.1/Aria10gx
Hello Sir/Madam, Quartus prime pro 17.1 + Modelsim 10.5c +Arria10gx I generated an Intel FFT ipcore from Quartus, I can see some files have been generated under the tfft_17_1_0_240_restored\ft\sim\...
RichardT_altera
6 years agoAs long as the IP core simulation involves the following steps, you should get it right.
1. Generate simulation model, testbench (or example design), and simulator setup script files.
2. Set up your simulator environment and any simulation scripts.
3. Compile simulation model libraries.
4. Run your simulator.
Those are top-level files, you need to add your own stimulus to it.
For bfm simulation, you can try out the design example below and the document below.
