User1582192733150209
6 years agoIntel fft simulation with Modelsim 10.5c starter version /Quartus prime pro 17.1/Aria10gx
Hello Sir/Madam, Quartus prime pro 17.1 + Modelsim 10.5c +Arria10gx I generated an Intel FFT ipcore from Quartus, I can see some files have been generated under the tfft_17_1_0_240_restored\ft\sim\...
RichardT_altera
6 years agoAs you mentioned this was many years ago, the IP may have been upgraded along the way.
Rest assured, in order to generate a simulation testbench, in the IP parameter editor, click Generate > Generate Testbench System. Specify testbench generation options, and then click Generate. A testbench directory will be generated.
You can refer to this page for further details.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf#page=70
p.s. Don’t forget to Reply, and Select the Best Solution. :)
