Instantiation of DDR3 SDRAM Controller with UniPHY intel FPGA IP
Hi Adzim,
Sorry for late reply. Because I can not reply your pose until now.
Currently, we have re-designed the hardware, and add a 50M oscillator and assign its' output to one pin of DQ I/O bank. Unfortunately, the DDR3 still can not work with 300M frequency. Through the "cheating method" described above, the DDR can work at 150M Hz.
The timing report of DDR controller is as following:
Initializing DDR database for CORE ddrc_p0
Finding port-to-pin mapping for CORE: ddrc_p0 INSTANCE: ddrc_u|ddrc_inst
Report Timing: Found 10 setup paths (0 violated). Worst case slack is 1.461
Report Timing: Found 10 hold paths (0 violated). Worst case slack is 0.303
Report Timing: Found 10 recovery paths (0 violated). Worst case slack is 11.060
Report Timing: Found 10 removal paths (0 violated). Worst case slack is 0.834
Core: ddrc_p0 - Instance: ddrc_u|ddrc_inst
setup hold
Address Command (Slow 1100mV 85C Model) | 0.975 0.968
Bus Turnaround Time (Slow 1100mV 85C Model) | 5.512 --
Core (Slow 1100mV 85C Model) | 1.461 0.303
Core Recovery/Removal (Slow 1100mV 85C Model) | 11.06 0.834
DQS vs CK (Slow 1100mV 85C Model) | 0.45 0.562
Postamble (Slow 1100mV 85C Model) | 0.817 0.817
Read Capture (Slow 1100mV 85C Model) | 0.315 0.268
Write (Slow 1100mV 85C Model) | 0.366 0.366
BTW, in the "report top failing paths", there are some setup slack violations of NIOS address and data bus ( in our design, there is a NIOS implemented ), I am not sure if these timing violations will affect the DDR operation.
Scott
