Instantiation of 9x9 multipliers in cyclone V GT FPGA?
For your information, as I look into your design, I notice that there seems to be multiple LogicLock regions which are overlapping with each other. I have removed all the regions and then create a new region with only 210 DSP block. The design can pass Fitter and result in 210 DSPs utilization. I have sent the updated QAR to you through email.
Regarding your Q2 and Q3 which is specific to LogicLock, I believe we might need the SW expert to further assist. Since I am unable to duplicate a case (not sure why, but believe due to access issue), would you mind to open a new case in this Forum with title specific to LogicLock. You may then let me know the case number so that I could help to expedite the routing.
Chee Pin
