15 years agoinput clock pin to 4 PLLs in a way Quartus is happy with
I am not entirely sure how to get round this. I have one input clock pin (my main system clock) and would like to route it to all four corner PLLs in my Arria 2 device. The Arria device I am using only has the 4 corner PLLs. I am using the 4 PLLs to drive altmemphy DDR3 interfaces running at 400MHz.
Although it is physically possible to route the input clock to all 4 PLL inputs, the way the clock pin input paths are, you can only route a clock input pin to 2 PLLs in a way that Quartus is happy with. If you route to all 4 you get the following warnings on the PLLs the clock is not optimal for. Critical Warning: PLL clock altmemphy_c_i|C_altmemphy_alt_mem_phy_inst|clk|half_rate.pll|altpll_component|auto_generated|pll1|clk[1] driven through clock routing. To ensure minimum jitter on memory interface clock outputs, the PLL clock source should be a dedicated clock pin on the same side. Critical Warning: PLL clock altmemphy_d_i|D_altmemphy_alt_mem_phy_inst|clk|half_rate.pll|altpll_component|auto_generated|pll1|clk[1] driven through clock routing. To ensure minimum jitter on memory interface clock outputs, the PLL clock source should be a dedicated clock pin on the same side. Is there a way round this or do I have to do something on the outside of the chip such as sending my oscillator to two different inputs which meet the clock input pin to PLL requirement Any guidance would be gratefully recieved. C
