Inferring Simple dual-port RAM with write enable & read enable
- 2 years ago
read-during-write behaviour is only critical for same address applied to read andwrite port simultaneously.
MAX10 M9K as well as e.g. Arria 10 M20K support "old-data" or "don't care" mode for single clock DP RAM. "new data" isn't supported and needs to be emulated by additional registers and read data mux if required in your application.
I don't recognize at first sight if read-during-write behaviour is relevant for you application. It can be best checked in a simulation.
My previous post needs to be corrected. It's not a problem of missing rden port, M9K actually has a rden port and the device handbook suggests to use if for power saving.
Problem is the doubled connection of rden in your code
always @ (posedge wclk) beginif (we) beginram[waddr] <= wdata;endif (re) beginr_rdata_1P <= ram[raddr];r_rdata_2P <= r_rdata_1P;endendgenerateif (OUTPUT_REG == "TRUE")assign rdata = r_rdata_2P;elseassign rdata = r_rdata_1P;endgenerate
Only the second assignment should be gated by (re). Doing so stops dual-clock RAM inference and removes the warnigs.
According to my experience, RAM read enable is rarely necessary in designs, the function can be achieved by other means like separate output register.
Thank you for your answer.
I try changing design you recommend.
AUDIY
