k_dz
1 year agoInferring RAM with byte-enable from parametrized SystemVerilog
I'm trying to write RAM with byte-enable inputs with parametrizable number of bytes. Templates for RAM with byte-enable in Lite and Standard versions of Quartus assume a certain number of bytes in a ...
- 1 year ago
Thanks for your design, after investigation, this user guide only can be used of Quartus Pro related devices.(Statix 10, Agilex 7 and etc).
It will not be applicable for Std edition, https://www.intel.com/content/www/us/en/docs/programmable/683082/24-3/ram-with-byte-enable-signals.html#mwh1409959589276__example_SystemVerilog_Simple
In your Quartus, if your right click and insert template, you will see this example in standard edition.
RichardT_altera
1 year agoMay I know if you need further help regarding this case?
Richard Tan
