k_dz
1 year agoInferring RAM with byte-enable from parametrized SystemVerilog
I'm trying to write RAM with byte-enable inputs with parametrizable number of bytes. Templates for RAM with byte-enable in Lite and Standard versions of Quartus assume a certain number of bytes in a ...
- 1 year ago
Thanks for your design, after investigation, this user guide only can be used of Quartus Pro related devices.(Statix 10, Agilex 7 and etc).
It will not be applicable for Std edition, https://www.intel.com/content/www/us/en/docs/programmable/683082/24-3/ram-with-byte-enable-signals.html#mwh1409959589276__example_SystemVerilog_Simple
In your Quartus, if your right click and insert template, you will see this example in standard edition.
KennyT_altera
1 year agoI tested with the inserted template from Quartus Prime Std, it does not able to infer the M10K as well. What you will need to do is to use the IP directly from the Quartus Prime Std in order to infer it.
