k_dz
1 year agoInferring RAM with byte-enable from parametrized SystemVerilog
I'm trying to write RAM with byte-enable inputs with parametrizable number of bytes. Templates for RAM with byte-enable in Lite and Standard versions of Quartus assume a certain number of bytes in a ...
- 1 year ago
Thanks for your design, after investigation, this user guide only can be used of Quartus Pro related devices.(Statix 10, Agilex 7 and etc).
It will not be applicable for Std edition, https://www.intel.com/content/www/us/en/docs/programmable/683082/24-3/ram-with-byte-enable-signals.html#mwh1409959589276__example_SystemVerilog_Simple
In your Quartus, if your right click and insert template, you will see this example in standard edition.
KennyT_altera
1 year agoCan you attached your design.qar file for the investigation?
k_dz
1 year agoHere's the project archive containing both the version with for (set as top level, not inferred as RAM) and the one that has been manually unrolled (inferred as RAM). The _w_output archive additionally contains report files.
