13 years agoinclude file in a vhdl file ...
I need to include a computer generated vhdl file (including constants) in another vhdl file. I could generate the full file (so the header etc etc ) with my C code, but would be more clean to include the constants separately in the hand written file. Just to explain: CURRENTLY: use ieee.std_logic_unsigned.all; package common_defs is -- constant constant ENGINES_NUMBER : integer := 3; -- number of instanciated engines -- Types type INTERSECT is array (0 to 5) of std_logic_vector(11 downto 0); type INTERSECT_ARRAY is array (0 to ENGINES_NUMBER) of INTERSECT; constant ENGINE_INT_X : INTERSECT_ARRAY := ((X"010",X"020",X"030",X"040",X"050",X"060"), (X"010",X"020",X"030",X"040",X"050",X"060"), (X"010",X"020",X"030",X"040",X"050",X"060"), (X"010",X"020",X"030",X"040",X"050",X"060")) ; constant ENGINE_INT_Y : INTERSECT_ARRAY := ((X"011",X"021",X"030",X"040",X"050",X"061"), (X"011",X"021",X"030",X"040",X"050",X"061"), (X"011",X"021",X"030",X"040",X"050",X"061"), (X"011",X"021",X"030",X"040",X"050",X"061")) ; end common_defs; While I'd like something : use ieee.std_logic_unsigned.all; package common_defs is -- constant constant ENGINES_NUMBER : integer := 3; -- number of instanciated engines -- Types type INTERSECT is array (0 to 5) of std_logic_vector(11 downto 0); type INTERSECT_ARRAY is array (0 to ENGINES_NUMBER) of INTERSECT; INCLUDE constants.vhd; -- HOW DO I DO IT ????????????????????????????????????? end common_defs; and constants.vhd is like: constant ENGINE_INT_X : INTERSECT_ARRAY := ((X"010",X"020",X"030",X"040",X"050",X"060"), (X"010",X"020",X"030",X"040",X"050",X"060"), (X"010",X"020",X"030",X"040",X"050",X"060"), (X"010",X"020",X"030",X"040",X"050",X"060")) ; constant ENGINE_INT_Y : INTERSECT_ARRAY := ((X"011",X"021",X"030",X"040",X"050",X"061"), (X"011",X"021",X"030",X"040",X"050",X"061"), (X"011",X"021",X"030",X"040",X"050",X"061"), (X"011",X"021",X"030",X"040",X"050",X"061")) ; and it is computer generated. Is that possible ? thanks franco
