in 20.1 synthesis embedded pragma support for vhdl --synthesis library xxx appears to have been removed or is it part of the licensed versions now ?
Hi Chris,
What do you mean by not working? Is there any possible error message(s) and snapshots you could provide?
Refer to link below for VHDL Synthesis Attributes and Directives
https://www.intel.com/content/www/us/en/programmable/quartushelp/13.0/mergedProjects/hdl/vhdl/vhdl_file_dir.htm
See below the output. First line of bsv_pkg.vhd is the embedded pragma --synthesis library bsv
This pragma works in previous version of quartus.
Info: *******************************************************************
Info: Running Quartus Prime Synthesis
Info: Version 20.1.0 Build 177 04/06/2020 SC Pro Edition
Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Mon Jun 8 14:29:22 2020
Info: System process ID: 217156
Info: Command: quartus_syn --64bit --analysis_and_elaboration --write_settings_files=off onewire
Info: Using INI file /home/chris/opencpi_clean/projects/core/hdl/primitives/ocpi/target-cyclone/quartus.ini
Info: qis_default_flow_script.tcl version: #2
Info: Initializing Synthesis...
Info: Project = "onewire"
Info: Revision = "onewire"
Info: Analyzing source files
Error (17816): VHDL error at bsv_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 1
Error (13827): Ignored construct bsv at bsv_pkg.vhd(161) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/bsv/cyclone/bsv_pkg.vhd Line: 161
Error (17816): VHDL error at fixed_float_types_pkg.vhd(1): synthesis directive "library" is not supported File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 1
Error (13827): Ignored construct fixed_float_types at fixed_float_types_pkg.vhd(35) due to previous errors File: /home/chris/opencpi_clean/projects/core/hdl/primitives/lib/fixed_float/cyclone/fixed_float_types_pkg.vhd Line: 35
