SteveS109's avatar
SteveS109
1 year ago
Implementing MIPI DSI-2 on an Agilex 5 device
I'm using the Agilex 5 FPGA E-Series 065B Premium Development Kit.
There isn't much documentation - so I decided to generate the design example and run the simulation in Questa. I generated and ran the "full simulation" design example (MIPI DSI-2 Rx+Tx Simulation) in Quartus 25.1.1. The simulation fails almost immediately the with error "axis_m does not accept back pressure." I'm not sure if we should try to force the "axi4s_vin_in_tready" to always high or if something else in the design should be changed.
So, there doesn't seem to be documentation on how to implement MIPI DSI-2 and the functional simulation doesn't work.
Ultimately, I'm looking for documentation or a functional simulation that shows how to implement MIPI DSI-2 on an Agilex 5 FPGA.
  • Anonymous's avatar
    Anonymous
    Not applicable
    Hi SteveS109​ ,
    Nice to work with you back, sorry for the delay of response due to the forum migration.
    Is it something really important to you ?
    The official user guide is coming to out in 1-2 month later. I suggest to refer to that if possible.
    Wincent
    • SteveS109's avatar
      SteveS109
      Yes - it is very important to the project and cannot wait.  Anything you can do to help us is much appreciated.
        Anonymous
        Not applicable
        Hi Steve,
        Do you run "analysis and synthesis(at least)" or full compilation after you generate the design ?
        Wincent
    SteveS109
    The top-level Verilog module ports for the IP are as follows:
    I think guidance on how to generate a blackbox IP component for this is what is needed along with top-level connections including what needs to be exported.
    // dsi2_dphy_sys.v
    // Generated using ACDS version 25.3 109
    `timescale 1 ps / 1 ps
    module dsi2_dphy_sys (
    		input  wire        dsi2_tx_control_write,                                  //                                  dsi2_tx_control.write
    		input  wire        dsi2_tx_control_read,                                   //                                                 .read
    		input  wire [8:0]  dsi2_tx_control_address,                                //                                                 .address
    		input  wire [31:0] dsi2_tx_control_writedata,                              //                                                 .writedata
    		output wire [31:0] dsi2_tx_control_readdata,                               //                                                 .readdata
    		output wire        dsi2_tx_control_readdatavalid,                          //                                                 .readdatavalid
    		output wire        dsi2_tx_control_waitrequest,                            //                                                 .waitrequest
    		input  wire [3:0]  dsi2_tx_control_byteenable,                             //                                                 .byteenable
    		input  wire [47:0] dsi2_tx_axi4s_vid_in_tdata,                             //                             dsi2_tx_axi4s_vid_in.tdata
    		input  wire        dsi2_tx_axi4s_vid_in_tvalid,                            //                                                 .tvalid
    		output wire        dsi2_tx_axi4s_vid_in_tready,                            //                                                 .tready
    		input  wire        dsi2_tx_axi4s_vid_in_tlast,                             //                                                 .tlast
    		input  wire [5:0]  dsi2_tx_axi4s_vid_in_tuser,                             //                                                 .tuser
    		input  wire        dsi2_tx_frame_start_conduit,                            //                              dsi2_tx_frame_start.conduit
    		output wire        dsi2_tx_axi4s_clk_bridge_out_clk_clk,                   //                 dsi2_tx_axi4s_clk_bridge_out_clk.clk
    		output wire        dsi2_tx_axi4s_reset_bridge_out_reset_reset,             //             dsi2_tx_axi4s_reset_bridge_out_reset.reset
    		input  wire        mipi_dphy_rzq_rzq,                                      //                                    mipi_dphy_rzq.rzq
    		input  wire        mipi_dphy_ref_clk_0_clk,                                //                              mipi_dphy_ref_clk_0.clk
    		input  wire [11:0] mipi_dphy_axi_lite_awaddr,                              //                               mipi_dphy_axi_lite.awaddr
    		input  wire        mipi_dphy_axi_lite_awvalid,                             //                                                 .awvalid
    		output wire        mipi_dphy_axi_lite_awready,                             //                                                 .awready
    		input  wire [31:0] mipi_dphy_axi_lite_wdata,                               //                                                 .wdata
    		input  wire [3:0]  mipi_dphy_axi_lite_wstrb,                               //                                                 .wstrb
    		input  wire        mipi_dphy_axi_lite_wvalid,                              //                                                 .wvalid
    		output wire        mipi_dphy_axi_lite_wready,                              //                                                 .wready
    		output wire [1:0]  mipi_dphy_axi_lite_bresp,                               //                                                 .bresp
    		output wire        mipi_dphy_axi_lite_bvalid,                              //                                                 .bvalid
    		input  wire        mipi_dphy_axi_lite_bready,                              //                                                 .bready
    		input  wire [11:0] mipi_dphy_axi_lite_araddr,                              //                                                 .araddr
    		input  wire        mipi_dphy_axi_lite_arvalid,                             //                                                 .arvalid
    		output wire        mipi_dphy_axi_lite_arready,                             //                                                 .arready
    		output wire [31:0] mipi_dphy_axi_lite_rdata,                               //                                                 .rdata
    		output wire [1:0]  mipi_dphy_axi_lite_rresp,                               //                                                 .rresp
    		output wire        mipi_dphy_axi_lite_rvalid,                              //                                                 .rvalid
    		input  wire        mipi_dphy_axi_lite_rready,                              //                                                 .rready
    		input  wire [2:0]  mipi_dphy_axi_lite_arprot,                              //                                                 .arprot
    		input  wire [2:0]  mipi_dphy_axi_lite_awprot,                              //                                                 .awprot
    		output wire        mipi_dphy_reg_bus_reg_wr_en_o,                          //                                mipi_dphy_reg_bus.reg_wr_en_o
    		output wire        mipi_dphy_reg_bus_reg_rd_en_o,                          //                                                 .reg_rd_en_o
    		output wire [10:0] mipi_dphy_reg_bus_reg_raddr_o,                          //                                                 .reg_raddr_o
    		output wire [10:0] mipi_dphy_reg_bus_reg_waddr_o,                          //                                                 .reg_waddr_o
    		output wire [3:0]  mipi_dphy_reg_bus_reg_be_o,                             //                                                 .reg_be_o
    		output wire [31:0] mipi_dphy_reg_bus_reg_din_o,                            //                                                 .reg_din_o
    		input  wire [31:0] mipi_dphy_reg_bus_reg_dout_i,                           //                                                 .reg_dout_i
    		output wire        mipi_dphy_LINK1_link_core_srst_reset_n,                 //                   mipi_dphy_LINK1_link_core_srst.reset_n
    		output wire [1:0]  mipi_dphy_LINK1_dphy_io_dphy_link_dp,                   //                          mipi_dphy_LINK1_dphy_io.dphy_link_dp
    		output wire [1:0]  mipi_dphy_LINK1_dphy_io_dphy_link_dn,                   //                                                 .dphy_link_dn
    		output wire        mipi_dphy_LINK1_dphy_io_dphy_link_cp,                   //                                                 .dphy_link_cp
    		output wire        mipi_dphy_LINK1_dphy_io_dphy_link_cn,                   //                                                 .dphy_link_cn
    		output wire        mipi_dphy_link1_link_core_clock_bridge_out_clk_clk,     //   mipi_dphy_link1_link_core_clock_bridge_out_clk.clk
    		output wire        mipi_dphy_link1_link_core_reset_bridge_out_reset_reset  // mipi_dphy_link1_link_core_reset_bridge_out_reset.reset
