16 years agoImplementing a program counter
Hello!
Im implementing a CPU, so i need a PC (program counter). My instructions are at PC because we dont need to have a memory. My problem is: My BEQ instruction is delayed by one instruction (BEQ is like something, if register1 = register2 then jump) Example: move r1,10 <- execute move r2,10 <-execute beq r1,r2,line5 <-execute add r1,r2 <- execute and jump move r3,r1 line5: sub r1,r2 <- continue... i dont know why it is executing the next instruciton (add) then jumping. Is it a delay problem? thanks in advance. I'm Using quartus web edition.library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity PC is
port(
input : in std_logic_vector(7 downto 0);
output : out std_logic_vector(7 downto 0);
PCin :in std_logic;
address : in std_logic_vector(3 downto 0);
PCJR: in std_logic;
PCJump: in std_logic;
BEQ: in std_logic;
BEQ_control : in std_logic;
clock : in std_logic;
indice : out std_logic_vector(7 downto 0)
end PC;
architecture logic of PC is
type instructions is array(0 to 8) of std_logic_vector(7 downto 0);
signal ins : instructions;
--signal aux : std_logic_vector(7 downto 0);
--signal canJump : std_logic;
begin
--Instructions
ins(0) <= "11000001";
ins(1) <= "11001011";
ins(2) <= "00100011";
ins(3) <= "11000010";
ins(4) <= "11011010";
ins(5) <= "11011110";
ins(6) <= "11011001";
ins(7) <= "11000101";
ins(8) <= "01100110";
process(clock)
variable ind : integer :=0;
begin
if(clock'event and clock = '1') then
if(PCin = '1') then -- send instruction and increment
output <= ins(ind);
ind := ind + 1;
--indice <= CONV_STD_LOGIC_VECTOR(ind,8);
elsif(PCJR = '1') then -- JR
ind := CONV_INTEGER(UNSIGNED(input));
elsif(PCJump = '1') then --JUmp
ind := CONV_INTEGER(UNSIGNED(address));
elsif(beq = '1') then
if(beq_control = '1') then
-- PC - 8
ind := ind - (CONV_INTEGER(UNSIGNED(address)));
else
--PC + 8
ind := ind + (CONV_INTEGER(UNSIGNED(address)));
end if;
end if;
--output <= aux;
end if;
ind := ind;
end process;
end logic;
