I'm using Quartus Prime Lite, and I keep getting a license-related error.
I'm having trouble running a simulation with the University Program's VWF in Quartus Prime Lite. It keeps failing with a license-related error. What should I do?
- FvM
missing info, Quartus and simulator version, specifically Modelsim or Questa. Most likely reason: You are using Questa Starter Edition and didn't yet acquire and install a free license. Follow the instructions. - ShengN_altera
Quartus Prime Lite and VWF not need license. Could you check other version got error?
Sheng
- DrRussMeierMSOE
Sheng,
I can absolutely confirm as a university professor with 100 students using Quartus Prime Lite 24.1 and Questa-Sim that using the VWF graphical waveform editor and QuestaSim simulation requires a free license for QuestaSim. You will receive an error message until you acquire a license.
With my students, I use this workflow on Microsoft Windows:
- Use Quartus --> Tools --> License Setup --> Get No Cost Licenses
- After acquiring a license file, a confirmation dialog will appear with the pathname of the file. Mouse highlight and copy that path name.
- Ensure Use LM_LICENSE_FILE_variable is checked in the same dialog box
- Open the Command Prompt application.
- In Command Prompt: setx LM_LICENSE_FILE <<paste in path>>
- Reboot computer
- Ensure the Use LM_LICENSE_FILE checkbox is checked. It should be prepopulated with your path name now.
Russ
- ShengN_altera
May I know do you have any further concern?
Sheng
- ShengN_altera
Yes, the Questasim need the evaluation license.
May I know does the problem resolved after those steps performed?
Sheng
- DrRussMeierMSOE
Sheng,
Yes, the steps above for me do indeed work across 100 students.
