MSura2
6 years agoI'm having an issue using the Atomic Library in C++11, it's saying that I need to specify the flag std=c++11, but I don't know how to do that with I++ compiler. How do I correct this, since I need Compare and Swap behavior for my data structure?
Whereby when compiling my code with the command: g++ src/fpga_basic.cpp -march=x86-64 -std=c++11 -o test-x86_64 It compiles correctly and executes the behavior that is expected. However, when I t...
AnilErinch_A_Intel
6 years agoHi
You can try with OpenCL instead of HLS , if you want to try atomic instructions in Intel FPGAs.
Please refer the OpenCL guide as given below
https://www.intel.com/content/www/us/en/programmable/documentation/mwh1391807965224.html
Regarding the Arria 10 Device support in Quartus 20.1 , please make sure that you have installed the device support files (.QDZ) for Arria10 and use it in Quartus 20.1 . The device files can be downloaded from the below link.
https://fpgasoftware.intel.com/
Thanks and Regards
Anil
