1 Reply
You need to constrain your input clock with a "create_clock command".
Then you need to constrain the PLL output clocks, using the "derive_pll_clocks" command.
What does it mean when the clock I use everywhere in the design, which happens to be the output of a PLL, is shown as "illegal" in the timing analyser clock status summary? And the raw clock input that feeds only the PLL and nothing else, is shown as "unconstrained" ?
