Identify two ISP instances
- 1 year ago
Hi Masaru,
Will reflect that to internal engineering team for enhancement.
Sheng
If they generated only one instance of the IP, they would not be able to set different instance IDs for the two copies. In fact, they may show up with the same instance ID in the ISSP file but with different indices selected by the tool.
Thank you for your reply.
I have generated IP with Automatic Instance Index Assignment option set.
When compiling the project, Quartus automatically assigned instance id on all instances.
But problem is I can't find any information in synthesis report or fitter report file.
My test project grows big and finally I have four instances in it.
I could identify the instance from the behaviour of connected signals, you pointed out this method.
Another workaround, contributor FvM guided me not to use Automatic Instance Index Assignment option.
I would like to hear from altera person.
