JDesr1
6 years agoI have installed Quartus Prime on a Win 10 PC. When I use the programmer application it won't recognize the presence of my USB Blaster.
I used to use Quartus II version 14 on a Win 7 PC and had no problems programming devices. The Win 7 PC will eventually not be supportable and I'd like to transfer the functionality to a newer Win 10...
sstrell
6 years agoSo it shows up in Device Manager but not in the Programmer under the Hardware Setup button? Are you connecting to a dev kit that has the onboard USB Blaster (so you just need a USB cable) or a board with the 10-pin JTAG connector required for the USB Blaster "pod"?
#iwork4intel
