NPark13
6 years agoI did quatus install but it didn't work. As a result of the check, it was running in the background process of the task manager. Even if you install another ver., It does not run the same way, but only in the background. How can I run quatus?
1 Reply
- SyafieqS
Hi Neo,
Make sure your machine spec meet the requirement of the Quartus that you want to use. If so, I suggest try to reinstall it and rerun it again. Let see if it works. Refer to link below for the specification requirement.
https://fpgasoftware.intel.com/requirements/
