13 years agoI can't launch modelsim-altera software
Hi everyone. I am using Quartus II 9.0 Web Edition and Modelsim-Altera 6.4a Starter Edition under win7 and win8.I'm getting the same error in both OS. After compiling,when I start the simu...
13 years ago --- Quote Start --- That's weird. AFAIK, both Quartus Web Edition and Modelsim-Altera Starter Edition don't require any license file to run. Have you tried uninstalling ModelSim-Altera and reinstalling it? --- Quote End --- I installed it several times; I tried to install Quartus first, ModelSim 2nd, and vice versa. The result is the same always. I suspected my test project and I looked also in some hidden files, which might be corrupt for any reason. I found an invisible directory in my home folder with the general Altera settings. I erased it, re-installed the SW and created a new project. No luck! Tomorrow I will try to install it at a different workstation with RedHat 5 (instead of CentOS 6.4).
