13 years agoI can't launch modelsim-altera software
Hi everyone. I am using Quartus II 9.0 Web Edition and Modelsim-Altera 6.4a Starter Edition under win7 and win8.I'm getting the same error in both OS. After compiling,when I start the simu...
13 years ago --- Quote Start --- Hi everyone. I am using Quartus II 9.0 Web Edition and Modelsim-Altera 6.4a Starter Edition under win7 and win8.I'm getting the same error in both OS. After compiling,when I start the simulation,I got three errors: Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. Error: NativeLink simulation flow was NOT successful Error: Quartus II Full Compilation was unsuccessful. 3 errors, 5 warnings I uninstall QuartusII and Modelsim-Altera and install again many times , but it wasn't work. Please help me --- Quote End --- Are you able to perform Analysis and Elaboration successfully? If yes, try to do RTL Simulation again using NativeLink. --- Quote Start --- I have the same problem here. My configuration:
- OS CentOS 6.4 64 bit, 8 GByte physical RAM
- 12.1sp1_243_modelsim_ase_linux
- 12.1sp1_243_quartus_free_linux
- Cyclone V: 5CGXBC4C6F23C7
