Длаза
6 years agoI can't install devices arria10 (all part). Why?
I did install quartus prime 18.0SE. Load devices "Arria10". When I launch Device Installer, in the “select components” window, after clicking next, a message appears: you didn't select any component...
sstrell
6 years agoSo it doesn't work even after pointing the device installer to the location of the .qdz files? Weird. I'd try downloading them again, double-checking to make sure they are the correct version of the files for the version of Quartus you've installed.
#iwork4intel
- Длаза6 years ago
I repeated downloading again and got the same result.
- sstrell6 years ago
If they’re grayed out like that, it means the device is already installed. Are you saying that when you create a new project or try to select an A10 device for an existing project that Quartus tells you the device is not installed? If so, I’d just uninstall Quartus and start over.
#iwork4intel
