viktormyhome's avatar
viktormyhome
6 months ago
hps_sdram_p0_pin_assignments.tcl script failed
Quartus 25.1, Cyclone V,  TCL script is failed with next messages. Please, help me to run it succesfully.
source "D:/Folder/Terasic/DE10-Nano_v.1.1.0_HWrevE_SystemCD/Tools/SystemBuilder/CodeGenerated/DE10_NANO/DE10_NANO_SPI/db/ip/hps/submodules/hps_sdram_p0_pin_assignments.tcl"
Error:Info: *******************************************************************
Error:Info: Running Quartus Prime Timing Analyzer
Error: Info: Version 25.1std.0 Build 1129 10/21/2025 SC Standard Edition
Error: Info: Copyright (C) 2025 Altera Corporation. All rights reserved.
Error: Info: Your use of Altera Corporation's design tools, logic functions
Error: Info: and other software and tools, and any partner logic
Error: Info: functions, and any output files from any of the foregoing
Error: Info: (including device programming or simulation files), and any
Error: Info: associated documentation or information are expressly subject
Error: Info: to the terms and conditions of the Altera Program License
Error: Info: Subscription Agreement, the Altera Quartus Prime License Agreement,
Error: Info: the Altera IP License Agreement, or other applicable license
Error: Info: agreement, including, without limitation, that your use is for
Error: Info: the sole purpose of programming logic devices manufactured by
Error: Info: Altera and sold by Altera or its authorized distributors. Please
Error: Info: refer to the Altera Software License Subscription Agreements
Error: Info: on the Quartus Prime software download page.
Error: Info: Processing started: Mon Feb 23 16:23:09 2026
Error:Info: Command: quartus_sta -t D:/Folder/Terasic/DE10-Nano_v.1.1.0_HWrevE_SystemCD/Tools/SystemBuilder/CodeGenerated/DE10_NANO/DE10_NANO_SPI/db/ip/hps/submodules/hps_sdram_p0_pin_assignments.tcl DE10_NANO_SPI
Error:Info: Quartus(args): DE10_NANO_SPI
Error:Info: Cleaning up stale assignments...
Error:Error (23031): Evaluation of Tcl script D:/Folder/Terasic/DE10-Nano_v.1.1.0_HWrevE_SystemCD/Tools/SystemBuilder/CodeGenerated/DE10_NANO/DE10_NANO_SPI/db/ip/hps/submodules/hps_sdram_p0_pin_assignments.tcl unsuccessful
Error:Error: Quartus Prime Timing Analyzer was unsuccessful. 1 error, 0 warnings
Error: Error: Peak virtual memory: 4670 megabytes
Error: Error: Processing ended: Mon Feb 23 16:23:09 2026
Error: Error: Elapsed time: 00:00:00
Error: Error: Total CPU time (on all processors): 00:00:00
Error:------------------------------------------------
Error:ERROR: Can't run the Timing Analyzer (quartus_sta) -- Partition Merge (quartus_cdb --merge) failed or was not run. Run the Partition Merge (quartus_cdb --merge) successfully before running the Timing Analyzer (create_timing_netlist -post_map).
Error: while executing
Error:"create_timing_netlist -post_map"
Error: invoked from within
Error:"if { ! [ timing_netlist_exist ] } {
Error: create_timing_netlist -post_map
Error:}"
Error: (file "D:/Folder/Terasic/DE10-Nano_v.1.1.0_HWrevE_SystemCD/Tools/SystemBuilder/CodeGenerated/DE10_NANO/DE10_NANO_SPI/db/ip/hps/submodules/hps_sdram_p0_pin_a..." line 174)
Error:"exec $cmd -t [ info script ] $project_name "
Error:"if { ![info exists quartus(nameofexecutable)] || ($quartus(nameofexecutable) != "quartus_sta" && $quartus(nameofexecutable) != "quartus_map") } {
Error: pos..."
Error: (file "D:/Folder/Terasic/DE10-Nano_v.1.1.0_HWrevE_SystemCD/Tools/SystemBuilder/CodeGenerated/DE10_NANO/DE10_NANO_SPI/db/ip/hps/submodules/hps_sdram_p0_pin_a..." line 110)
Error:"_source D:/Folder/Terasic/DE10-Nano_v.1.1.0_HWrevE_SystemCD/Tools/SystemBuilder/CodeGenerated/DE10_NANO/DE10_NANO_SPI/db/ip/hps/submodules/hps_sdram_..."
Error: ("uplevel" body line 1)
Error:"uplevel 1 $cmd "
Error: (procedure "source" line 5)
Error:"source "D:/Folder/Terasic/DE10-Nano_v.1.1.0_HWrevE_SystemCD/Tools/SystemBuilder/CodeGenerated/DE10_NANO/DE10_NANO_SPI/db/ip/hps/submodules/hps_sdram_..."
  • I am going to use HPS_GPIO,64,65,66 pins from Cyclone V formware. Just to use in code without Quartus as I understand is not possible. I have to initialize these HPS GPIOs in Quartus. I try to do this:
    module DE10_NANO_SPI(
    inout HPS_GPIO64,
    inout HPS_GPIO65,
    inout HPS_GPIO66
    hps u0 (
    .hps_io_hps_io_gpio_inst_GPIO64 (HPS_GPIO64), // .hps_io_gpio_inst_GPIO64
    .hps_io_hps_io_gpio_inst_GPIO65 (HPS_GPIO65), // .hps_io_gpio_inst_GPIO65
    .hps_io_hps_io_gpio_inst_GPIO66 (HPS_GPIO66) // .hps_io_gpio_inst_GPIO66
    And during Partition Merge have got next warnings and errors. Please, suggest what is not correct.
    Critical Warning (35033): Found I/O pins in lower-level partitions that are not connected in the top-level design
    Critical Warning (35034): I/O cell "hps:u0|hps_hps_0:hps_0|hps_hps_0_hps_io:hps_io|hps_hps_0_hps_io_border:border|hps_io_gpio_inst_GPIO64[0]~output" is not connected to partition "hps_hps_0_hps_io_border:border"
    Critical Warning (35034): I/O cell "hps:u0|hps_hps_0:hps_0|hps_hps_0_hps_io:hps_io|hps_hps_0_hps_io_border:border|hps_io_gpio_inst_GPIO65[0]~output" is not connected to partition "hps_hps_0_hps_io_border:border"
    Critical Warning (35034): I/O cell "hps:u0|hps_hps_0:hps_0|hps_hps_0_hps_io:hps_io|hps_hps_0_hps_io_border:border|hps_io_gpio_inst_GPIO66[0]~output" is not connected to partition "hps_hps_0_hps_io_border:border"
    Error (35030): Partition "hps_hps_0_hps_io_border:border" contains I/O cells that do not connect to top-level pins or have illegal connectivity
    Error (13176): Port: I_GPIO2_PORTA_I of HPS atom "hps:u0|hps_hps_0:hps_0|hps_hps_0_hps_io:hps_io|hps_hps_0_hps_io_border:border|hps_io_gpio_inst_GPIO64[0]~output" must be connected to a top-level pin
    Error (13176): Port: I_GPIO2_PORTA_I of HPS atom "hps:u0|hps_hps_0:hps_0|hps_hps_0_hps_io:hps_io|hps_hps_0_hps_io_border:border|hps_io_gpio_inst_GPIO65[0]~output" must be connected to a top-level pin
    Error (13176): Port: I_GPIO2_PORTA_I of HPS atom "hps:u0|hps_hps_0:hps_0|hps_hps_0_hps_io:hps_io|hps_hps_0_hps_io_border:border|hps_io_gpio_inst_GPIO66[0]~output" must be connected to a top-level pin
    • viktormyhome's avatar
      viktormyhome
      In Platform Designer my HPS GPIOs looks like:
      I am going to use them as outs, writting 0 or 1 to their DR register, DDR register contains 1 - configured as out
