Sangamesh_NV
2 years agoHPS_CLK1 and HPS_CLK2 input clocks not present in HPS IP
Hi, Using quartus 22.1 std for cyclone V SoC. I have created an HPS IP using platform designer, Used the qip file into quartus project and did early pin planning using ppf file. The IO port list c...
EBERLAZARE_I_Intel
2 years agoHi,
Thanks for the update, does your design compilation working okay now?
Do you require further help on this ticket?
Sangamesh_NV
2 years agoHi,
Yes the design compilation is working fine.
Thank you for your response.
