Sangamesh_NV
2 years agoHPS_CLK1 and HPS_CLK2 input clocks not present in HPS IP
Hi, Using quartus 22.1 std for cyclone V SoC. I have created an HPS IP using platform designer, Used the qip file into quartus project and did early pin planning using ppf file. The IO port list c...
EBERLAZARE_I_Intel
2 years agoHi,
Do you have any update from your side?
- Sangamesh_NV2 years ago
Sorry for the delayed response.
Those two clock pins are assigned to dedicated locations in the pinout report generated after compilation.
But they are not present in the pin planner.
Anyways they are getting assigned as required.
