Sangamesh_NV
2 years agoHPS_CLK1 and HPS_CLK2 input clocks not present in HPS IP
Hi, Using quartus 22.1 std for cyclone V SoC. I have created an HPS IP using platform designer, Used the qip file into quartus project and did early pin planning using ppf file. The IO port list c...
sstrell
2 years agoThose are dedicated pins so they should be there. Check your device handbook and the HPS user guide to find the correct locations if you don't see them in the Pin Planner.
