12 years ago
How to write the 125 Mhz frequancy in a testbench vhdl language
I'm beginner in VHDL,
I have to devide the frequency from 125 Mhz to 1 Hz
for that I used this code to generate the 1s clock
--- generate the 1s clock ---
process(clk,rst)
begin
if rst='1' then
cnt<=1;
else
cnt<=cnt+1;
end if;
if cnt<=62000000 then
clk_s<='0';
else
clk_s<='1';
end if;
if cnt=125000000 then
cnt<=1;
end if;
end process;
the probleme is what's the value of clock (clk) I should define in testbensh ( is it 8ns ??)
help me please! thank you.
Abdallah.
    --- Quote Start ---
    process(clk,rst)
    begin
    if rst='1' then
    cnt<=1;
    else
    cnt<=cnt+1;
    end if;
    clk_s<='0';
    else
    clk_s<='1';
    end if;
    cnt<=1;
    end if;
    end process;
    Abdallah.
    --- Quote End ---
    in your testbench just write:
    clk <= not clk after 4 ns;
    thank you kaz
    ok now i'm sure about the 8ns.
    but the simulation dont provide result of 1s in the clock_s but it provide result of 0.5 s
    is the problem in the value of the counter?!!
    thanks!
    --- Quote Start ---
    thank you kaz
    thanks!
    --- Quote End ---
    your counter need to run from 0 to 125000000-1 freely
    you set logic to zero or one when count = [0, 125,000,000/2 -1] respectively, or so depending on duty cycle.
    process(rst,clk)
    begin
    if rst = '1' then
        count <= 0;
    elsif rising_edge(clk) then
    if count = 125000000-1 then
        count <= 0;
    else
       count <= count +1;
    end if;
    if count = 0 then
         clk_1s <= '0';
    elsif count = 125000000/2 -1 then
         clk_1s <= '1';
    end if;
    end if;
    end process;
    your simulation may get too long, you may scale it down by factor.
    You also need clock edge
