12 years ago --- Quote Start --- thank you kaz ok now i'm sure about the 8ns. but the simulation dont provide result of 1s in the clock_s but it provide result of 0.5 s is the problem in the value of the counter?!! ------- thanks! --- Quote End --- your counter need to run from 0 to 125000000-1 freely you set logic to zero or one when count = [0, 125,000,000/2 -1] respectively, or so depending on duty cycle.
process(rst,clk)
begin
if rst = '1' then
count <= 0;
elsif rising_edge(clk) then
if count = 125000000-1 then
count <= 0;
else
count <= count +1;
end if;
if count = 0 then
clk_1s <= '0';
elsif count = 125000000/2 -1 then
clk_1s <= '1';
end if;
end if;
end process;
your simulation may get too long, you may scale it down by factor. You also need clock edge
