14 years ago
How to use Avalon-MM Master BFM?
Hello, all.
I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI.
I wrote this program to test if the custom component can give right response to the Avalon Master BFM.
//Console messaging level
`define VERBOSITY VERBOSITY_INFO
//BFM hierachy
`define CLK_BFM     top.tb.clock_source
`define RST_BFM     top.tb.reset_source
`define MM_MASTER   top.tb.avalon_mm_master
`define CONDUIT_BFM top.tb.conduit_bfm
module test_program();
  import verbosity_pkg::*;
  import avalon_mm_pkg::*;
  event start_test;
  event end_test;
  // Set verbosity before the test starts
  // Qsys-generated testbench activates clock and reset BMFs
  initial begin
	set_verbosity(`VERBOSITY);
	// initialize BFMS
	`MM_MASTER.init();
  end
  // Main test block
  initial begin
	// wait for reset inactive
	wait(`RST_BFM.reset == 1);
		-> start_test;
  end
  initial begin
	@ start_test;
	// start write access
	`MM_MASTER.set_command_request(REQ_WRITE);
	`MM_MASTER.set_command_address(16'h0);
	`MM_MASTER.set_command_idle(2,0);
	`MM_MASTER.set_command_init_latency(0);
	`MM_MASTER.set_command_data(32'h0,0);
	`MM_MASTER.push_command();
  end
endmodule
Although this program can be compiled by ModelSim with no error, but it seems the write access was not started.
Can you give me some hints or some examples about how to test custom components wit Avalon IP verification suite?
feng
