14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
14 years ago --- Quote Start --- I'm using Quartus II 11.0 Web Edition, and I can't find the test_bench() module in my design file. Is the test_bench() module produced automatically by Qsys? --- Quote End --- Yes. Look at your own code ... `define CLK_BFM top.tb.clock_source The 'tb' entry in that hierarchy is the test_bench() component you want to copy and eliminate from the design. You'll copy the clock generator, the reset generator, and the Qsys system instance, and then you will have access to the ports on the Qsys system instance, so you can manipulate the exported ports. Cheers, Dave
