14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
14 years ago --- Quote Start --- Hi feng, Your code enqueues a transaction, but it does not wait for it to complete, so Modelsim exits too soon. Here's a couple of tasks I use:
// Tasks
// Avalon-MM single-transaction read and write procedures.
task avalon_write (
input addr,
input data
begin
// Construct the BFM request
`BFM.set_command_request(REQ_WRITE);
`BFM.set_command_idle(0, 0);
`BFM.set_command_init_latency(0);
`BFM.set_command_address(addr);
`BFM.set_command_byte_enable('1,0);
`BFM.set_command_data(data, 0);
// Queue the command
`BFM.push_command();
// Wait until the transaction has completed
while (`BFM.get_response_queue_size() != 1)
@(posedge clk);
// Dequeue the response and discard
`BFM.pop_response();
end
endtask
task avalon_read (
input addr,
output data
begin
`BFM.set_command_request(REQ_READ);
`BFM.set_command_data(0, 0);
@(posedge clk);
// Dequeue the response and return the data
data = `BFM.get_response_data(0);
end
endtask
Cheers, Dave --- Quote End --- I solved the problem using your tasks. Thanks, Dave. And I have another question. This custom component has an Avalon conduit interface connecting a LSI. I read the Conduit BFM section, and didn't find the right function. Can you tell me how to set the values of signals from the LSI? Best regards, feng
