MohdAnnuar_S_Intel
7 years agoHow to solve unexpected error in JTAG server -- error code 35?
This is seen on Windows Quartus prime pro version 17.1 programmer via USB Blaster II cable. I am trying to program FPGA on stratix 10 GX development board.
ShafiqY_Intel
7 years agoHi MSuha1,
I suspect your TCK frequency might be the root cause here.
Can you kindly try to reduce your TCK frequency to 6 MHz (default value)?
Below link is the command to change TCK frequency (on page 14= "2.8. Changing the TCK Frequency")
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf#page=14
Kindly try it out with your design and let me know the result.
Thanks😉
MDe_M1
6 years agoHi, I have the same problem when i try to program a max10 fpga in a new board developed by the hardware team. I don't how can I change the tck frequency because I am new about tcl scripting. Could you help me to set the right clock using tcl scripting? I have 17.0.0 Build 595 04/25/2017 SJ Lite Edition installed.
MDM
