16 years ago
How to share settings among several QII projects
I have one board layout that is used for several different FPGA designs. I want to share the parts of the settings that are the same among all the designs. The concept I want is an 'include' capability for settings. For example, all the designs have the same IO assignments, voltage, location, enables--they're all on the same board. But each design uses its own source files to define its logic.
How can I share my device and pin assignments, programming options, and other common settings across all the designs? With many designs and many pins, it can be very difficult to keep everything in step if there's a pin name change.
