How to recreate a timing failure on two different machines.
- 2 years ago
As long as you did not make any changes to your design and are using the same environment (machine), then you will be able to reproduce the same timing results regardless how much time has passed.
Nurina
Thank you very much for your reply sstrell.
Is there any way to make the compilation process somewhat deterministic? We have a requirement to be able to reproduce artifacts from a given repository state.
Do factors such as time of day/date affect the seed? Does the contents of a .mif/.hex file for initalising RAM contents have an effect?
So, for example, if I ran a compilation today, and then if I ran another compilation from the same repository state on the same machine two week later, would you expect the results to be the same?
When I was reading https://www.intel.com/content/www/us/en/docs/programmable/683145/21-3/change-fitter-placement-seeds.html it made no mention of different machines, etc. so I hoped there may be a way to do this.
