JHaye4
3 years agoHow to recreate a timing failure on two different machines.
We have a continuous integration job run each night to build our FPGA images, this runs on a server that we don't have access to for day to day working, it is dedicated to running CI jobs. Recently ...
- 2 years ago
As long as you did not make any changes to your design and are using the same environment (machine), then you will be able to reproduce the same timing results regardless how much time has passed.
Nurina
sstrell
3 years agoUsing the same seed number doesn't mean anything. If you compile the same project on two different machines, the seed is already different between them. It doesn't matter what seed number you select.
