JHaye4
3 years agoHow to recreate a timing failure on two different machines.
We have a continuous integration job run each night to build our FPGA images, this runs on a server that we don't have access to for day to day working, it is dedicated to running CI jobs. Recently ...
- 2 years ago
As long as you did not make any changes to your design and are using the same environment (machine), then you will be able to reproduce the same timing results regardless how much time has passed.
Nurina
JHaye4
3 years agoI have just triggered the job to run again and the compilation process in question has passed timing with no changes made to any of the contributing RTL.
Why do two different compilation runs with the same seed result in different results in timing? I thought setting the seed should make the process deterministic?
