How to purchase Intel IP cores licence?
I'm currently using Intel IP cores in Evaluation mode.
I would like to know how to purchase the license to utilize these IP cores in the production? What is the type of the license required for generating programming files for a product?
This is the list of FPGA IP cores used in the project:
1. PLL Intel FPGA IP
2. Modular SGDMA Dispatcher Intel FPGA IP
3. Write Master Intel FPGA IP
4. Avalon FIFO Memory Intel FPGA IP
5. Parallel I/O Intel FPGA IP
6. ALTCLKCTRL Intel FPGA IP
Other modules I'm using from the IP catalog:
1. Clock Source
2. Reset Bridge
3. Arria V/Cyclone V Hard Processor System
Thank you!
1 Reply
- KennyT_altera
If you use the lite edition of Quartus, the IP mention above does not require to be purhcase.
If you purchase the subscription edition, the license will include some IP
https://www.intel.com/content/www/us/en/programmable/products/intellectual-property/design/ip-base-suite.html
What I suggest is you try to run the evaluation mode
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an320.pdf
From there, see which license that you were missing in the assemble report. Then you can slowly purchase the IP that you want.
