How to program the FPGA/IC EPM7192SQC160-10 through Quartus II ?
Do you have a ByteBlaster or ByteBlasterII parallel port to JTAG programmer adapter (or an equivalent clone)?
Your system appears to support USB from the device manager picture, why not just use a UsbBlasterII (or a cheap clone)?
What version of Quartus are you running?
What version of Windows are you running?
The manual for the ByteBlasterII indicates that WindowsXP is the latest supported version of Windows.
Ref: https://cdrdv2-public.intel.com/654344/ug_bbii.pdf
There are driver install instructions in the above document.
That is the last OS I remember using a ByteBlaster on.
QuartusII 13.0sp1 available for download for free from the Intel download site supports the EPM7nnnS parts using the UsbBlaster.
Personally I would recommend using a UsbBlasterII or clone (you can get a clone for US$10 or less) and using QuartusII 13.0sp1.
For reference, the version of QuartusII you link to (13.1) does not support MAX device development; 13.0sp1 is the last version that does.
13.0sp1 runs fine on either Windows 7 64b and Windows 10 64b.
Forget about using the ByteBlaster thru the LPT port. It is a dead end.
Hi Intel Customer Support Service,
We're using Windows10 x64. I think I have installed the older version of Quartus. Let me try to reinstall back with the Quartus link you've provided.
I have seen the https://cdrdv2-public.intel.com/654344/ug_bbii.pdf, it seems this guideline is suit for those who're using Windows OS 2000/XP.
Maybe once I have installed the Quartus, and using the USB Blaster II, could you please share us what are the drivers that we should install and through Quartus how do we can perform the programming to the board ?
Thanks for your prompt response.
- _AK6DN_2 years ago
Watch this video about how to program an FPGA using Quartus and a USB Blaster:
Simple driver install instructions:
Applies to any USB Blaster or clone.
- Anbananthann2 years ago
Hi Customer Service,
This works.
I have tried using the instructions and able to perform the programming well.
Thanks for your support.
