My bad, I had overlooked the delays introduced by me in my testbench which were reflected in my output. Now that I'm giving input in every clock cycle after the first delay of 17 clock cycles, one output appears every new clock cycle.
--- Quote Start --- I aggree, that Altera could have added it as an option, but as mentioned above, it won't be of any use in the standard application, where a continous data stream is fed to the IP. --- Quote End --- Even a continuous data stream has a beginning (and in what most of us call a continuous video stream there are regular gaps) so an 'embedded' valid bit will almost always come in handy, and in case you really don't need it the complier would optimize it away.
