How to install older version of GCC compiler for HLS?
Yes, you need the same compiler for HLS.
For your Q19.3, you compiler is the same version. Right?
yes my quartus version and hls version is the same, and they are both 19.1
- gwatcha6 years ago
I tried not doing it my way and reverting the directory name change and following your suggestion. My resulting .bashrc looks like this:
export PATH=$PATH:/home/michael/Program/intelFPGA/19.1/modelsim_ase/bin export QUARTUS_ROOTDIR=/home/michael/Program/intelFPGA/19.1 export QSYS_ROOTDIR=/home/michael/Program/intelFPGA/19.1/quartus/sopc_builder/bin #GCC ENV for HLS export GCC_ROOTDIR=/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7 export PATH=$GCC_ROOTDIR:$PATH export LD_LIBRARY_PATH=/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/lib:$LD_LIBRARY_PATH export CPLUS_INCLUDE_PATH=/home/michael/Program/intelFPGA/19.1/hls/include:/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/include export LIBRARY_PATH=/home/michael/Program/intelFPGA/19.1/hls/host/linux64/lib source /home/michael/Program/intelFPGA/19.1/hls/init_hls.shYet I still get some errors due to gcc 10.1 being included
╭─ ~/Program/intelFPGA/19.1/hls/examples/counter ╰─❯ bash Assuming current directory (/home/michael/Program/intelFPGA/19.1/hls) is root of i++ Will use Quartus at /home/michael/Program/intelFPGA/19.1/hls/../quartus Will be using Modelsim at /home/michael/Program/intelFPGA/19.1/modelsim_ase/bin Adding /home/michael/Program/intelFPGA/19.1/hls/bin to PATH Adding /home/michael/Program/intelFPGA/19.1/hls/host/linux64/lib to LD_LIBRARY_PATH [michael@zen counter]$ make No target specified, defaulting to test-x86-64 Available targets: test-x86-64, test-fpga, test-gpp, clean i++ counter.cpp -I/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/include/c++ -I/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/include/c++/x86_64-pc-linux-gnu -march=x86-64 -o test-x86-64 In file included from counter.cpp:1: In file included from /home/michael/Program/intelFPGA/19.1/hls/include/HLS/hls.h:11: In file included from /home/michael/Program/intelFPGA/19.1/hls/include/HLS/hls_internal.h:10: In file included from /usr/lib/gcc/x86_64-pc-linux-gnu/10.1.0/../../../../include/c++/10.1.0/stdlib.h:36: /usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/include/c++/cstdlib:101:11: error: no member named 'div_t' in the global namespace using ::div_t; ~~^ /usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/include/c++/cstdlib:102:11: error: no member named 'ldiv_t' in the global namespace using ...Now my work around is to put this into the Makefile for the counter example:
CXXFLAGS := -I/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/include/c++ -I/usr/lib/gcc/x86_64-pc-linux-gnu/4.4.7/include/c++/x86_64-pc-linux-gnuAs well as changing the directory name:
/usr/lib/gcc/x86_64-pc-linux-gnu/10.1.0 -> /usr/lib/gcc/x86_64-pc-linux-gnu/10.1.0_To fool the compiler.
This fix dosen't get too far however, although `make test-x86-64` works, I get the following error when running `make test-fpga`
# vsim -t ps "+nowarnTFMPC" -L work -L work_lib -L tb_count_internal_10 -L tb_altera_irq_mapper_191 -L tb_avalon_split_multibit_conduit_10 -L tb_hls_sim_main_dpi_controller_10 -L tb_count_10 -L tb_avalon_conduit_fanout_10 -L tb_avalon_concatenate_singlebit_conduits_10 -L tb_hls_sim_component_dpi_controller_10 -L tb_hls_sim_clock_reset_10 -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L twentynm_ver -L twentynm_hssi_ver -L twentynm_hip_ver -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L twentynm -L twentynm_hssi -L twentynm_hip tb # Start time: 12:01:41 on Jul 16,2020 # ** Fatal: ** Error: (vsim-3827) Could not compile 'export_tramp.so': cmd = '/bin/gcc -shared -fPIC -m32 -g -I. -I"/home/michael/Program/intelFPGA/19.1/modelsim_ase/include" -I"/home/michael/Program/intelFPGA/19.1/modelsim_ase/../oem/include" -o "/tmp/michael@zen_dpi_29969/linuxpe_gcc-10.1.0/export_tramp.so" "/tmp/michael@zen_dpi_29969/linuxpe_gcc-10.1.0/export_tramp.S"' # (vsim-50) A call to system(/bin/gcc -shared -fPIC -m32 -g -I. -I"/home/michael/Program/intelFPGA/19.1/modelsim_ase/include" -I"/home/michael/Program/intelFPGA/19.1/modelsim_ase/../oem/include" -o "/tmp/michael@zen_dpi_29969/linuxpe_gcc-10.1.0/export_tramp.so" "/tmp/michael@zen_dpi_29969/linuxpe_gcc-10.1.0/export_tramp.S" >'/tmp/questatmp.775vJi' 2>&1) returned error code '1'. # The logfile contains the following messages: # gcc: fatal error: ‘-fuse-linker-plugin’, but liblto_plugin.so not found # compilation terminated. # # No such file or directory. (errno = ENOENT) # # # FATAL ERROR while loading design # ** Error: Error loading design # Executing ONERROR command at macro ./tb/sim/mentor/msim_compile.tcl line 8And I believe this is because the fix dosen't fool `vsim` (you can see it is looking for something in gcc 10.1 and can't find it).
So despite my fix, a proper solution would be nice.
There must be some kind of environment variable to set to have it include files from the right directory, right?
