gwatcha
6 years agoHow to install older version of GCC compiler for HLS?
I'm following the intel® high level synthesis compiler getting started guide for the Linux version it states that GCC compiler must be version 4.4.7 and newer ones are not supported.
I'm running M...
KennyT_altera
6 years agoHave you set the environment variable?
https://www.intel.com/content/www/us/en/programmable/documentation/ewa1462824960255.html#ewa1462897780080 look for --gcc-toolchain=<GCC_dir>
- gwatcha6 years ago
I tried setting that option earlier but I believe it is only for the Pro version, and I am using the Lite version (version 19.1, installed via additional software tab on quartus install page).
