CPR7
1 year agoHow to incorporate a VHDL file within Top level file in Quartus not using Platform Designer
Hello, I am somewhat new to FPGA and new to using Quartus IDE. My question is that I could not incorporate a file within the top level file that I created even after instantiating the .vhd file i...
KennyT_altera
1 year agoWhy don't you attached your design.qar files for us to take a look?
Also, for new user, you can try to look into https://community.intel.com/t5/FPGA-Wiki/University-Workshops/ta-p/735639 -> 4. FPGA Simulation & Debug
CPR7
1 year agoHello gentlemen,
I apologize for the late reply about my problem. Being less experience using the Quartus II IDE my problem is how do I include or add a file to my top level design? I tried to use the option "Add/remove file to the project" but during the compilation process it gave an error with particulars attached. I also attached the top level design. Thank you in advance for your assistance.
CPR7
- FvM1 year ago
according to compilation report, the design entity Hex7Seg isn't defined in any VHDL project file. Either the respective file hasn't been added to the project or it doesn't define the design entity correctly. We'd need to see the VHDL code to understand why.
Frank
