ICace
6 years agoHow to implement and simulate FFT IP with SimuLink on FPGA (Cyclone V GX starter kit) error vsim-3033
Hello, I am trying to implement the FFT block (with Quartus prime 19.1) but I cannot simulate it with simulink because I always get this error: ** Error: (vsim-3033) c:/intelfpga/17.1/quartus/bin6...
CheepinC_altera
6 years agoHi,
Thanks for your update. Regarding the test bench to feed data, there seems to be no specific manual or instruction on this. I would recommend you to refer to the example design generated from the IP which has the example test program which is reading data from text files to feed into the FFT IP.
Regarding the msim_setup.tcl generated together when you Generate Testbench, it is generated to compile libraries required for FFT simulation as well as the test bench generated. However, the test bench would require further edits ie to include the controls and the data feeding. I believe it is serving as a quick start for further edit.
Chee Pin
